pre cleaning for paint?
Exterior Body, Paint, Trim, Chrome
  1. Terry Kitzman
    Terry Kitzman Well-Known Member
    74
    5
    Apr 8, 2018
    S.E. Iowa
    Local Time:
    10:43 AM
    What kind of soap should I use?
  2. slimt
    slimt FBBO Gold Member FBBO Gold Member
    1,361
    1236
    Apr 17, 2017
    Alberta
    Local Time:
    9:43 AM
    what are you cleaning? what parts?
    • Agree Agree x 1
    • texas69bee
      texas69bee Well-Known Member
      1,642
      1066
      Dec 3, 2013
      texas
      Local Time:
      10:43 AM
      No soap, denatured alcohol
      • Thanks! Thanks! x 1
      • JimKueneman
        JimKueneman FBBO Gold Member FBBO Gold Member
        2,689
        2660
        Mar 25, 2016
        Sonoita, Az
        Local Time:
        8:43 AM
        Dawn and brush for sandblasted parts.
        • Agree Agree x 1
        • Islandkent
          Islandkent Well-Known Member
          125
          120
          Mar 9, 2019
          PEI, Canada
          Local Time:
          12:43 PM
          I agree with Jim. Just a little Dawn and hot water. Then rinse with hot hot water. The part dries better. Then blow dry with compressed air. Sometime I use a hair dryer on heat, so the part will dry quicker. I always wear nitrate gloves when washing small parts so not to get my skin oils on the part to prevent fish eyes. I also use gloves on the parts until they are painted and dry. I wash primed parts with Dawn also before final coat.
          Sure you can get all fancy with some wipe and wash, about 80 bucks a gallon but the soap will do just fine on small parts like suspension, brackets and hardware. Sure for the body and bigger panels use a proper wipe and wash.
          It works on the baby ducks just fine. lol
          • PurpleBeeper
            PurpleBeeper FBBO Gold Member FBBO Gold Member
            4,523
            3266
            Mar 20, 2011
            Chicago
            Local Time:
            10:43 AM
            All good advice above. Alcohol is an even better degreaser than soap/water....but soap/water is just fine and dawn or other dish soap is a great choice. If you want overkill, do soap/water followed by alcohol. The alcohol will help get all the water off and dries really fast (but flammable)
            • flypaper
              flypaper FBBO Gold Member FBBO Gold Member
              12,288
              19192
              Jul 17, 2008
              Local Time:
              11:43 AM
              I hate using water on any bare metal
              to me that promotes rust
              solvents only for me..
              • 1967coronet
                1967coronet FBBO Gold Member FBBO Gold Member
                954
                1036
                Jun 19, 2014
                Iowa
                Local Time:
                10:43 AM
                Depends on what is to be painted.
                suspension , rear end housing, bottom of car ect. degreaser & scrub , then pressure soap and water , repeat if needed.
                body steel after blasting, dawn dish soap and hot water, every inch of car, cowl, inside doors, hinges, qt window wells, and pillars 3X if soda blasted. Then wipe & blow dry and seal with epoxy.
                Primer on car just use PPG 330 grease and wax remover, wipe on with soaked new rag and follow with dry new rags allow time for evap before tac or sealer.
                If you soap and water the primer you need 3 dry days to get it out of the primer.
                • ddpsnake
                  ddpsnake Well-Known Member
                  601
                  419
                  Jun 18, 2017
                  Belleville Canada
                  Local Time:
                  11:43 AM
                  you guys are going to bark, but i use lighter fluid,cleans grease very well and leave no resude ready for primer.
                  • tak419
                    tak419 Well-Known Member
                    390
                    269
                    Mar 26, 2017
                    Ohio
                    Local Time:
                    11:43 AM
                    From a guy who paints. For bare metal parts acetone or wax and grease remover. For primed surface either wax and grease remover or Dawn and water. And allow to dry a day. For painted surfaces wax and grease remover or Dawn and water. My ratio is a Windex bottle full of water with about 5 drops Dawn. I wet sand all my parts with this solution.
                    • Agree Agree x 2
                    • Terry Kitzman
                      74
                      5
                      Apr 8, 2018
                      S.E. Iowa
                      Local Time:
                      10:43 AM
                      I am painting the body, It's down to bare metal, Just need to clean it for primer. Thank you.
                    • 69L48Z27
                      69L48Z27 FBBO Gold Member FBBO Gold Member
                      2,182
                      2047
                      Nov 19, 2015
                      York, Pa
                      Local Time:
                      11:43 AM
                      If it’s bare metal and your shooting the epoxy coat I would just use wax and grease remover. Product your using should also list what the proper cleaning products are for it.
                      • Agree Agree x 1
                      1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
                        By continuing to use this site, you are consenting to our use of cookies.
