PS bracket
RSZ28
7:14 PM
Brownsville, PA
Planning to replace the 273 with a 440 in my 65 Belvedere. Can I use the power steering from the small block on the 440 with just a big block bracket? If not, what do I need? Thanks
440 source.com has what you need.
I used the pump and brackets from the small block but it kept throwing belts, after buying all the right pulleys/brackets all was good.
Yes
I couldn't get the sb ps pulley to line up with the bb crank pulley. Bought a used bb pump to make it work on my 64.
