Hi guys! My 71 Charger is, well, overcharging. I first started noticing something was up when my Kenwood radio starting cutting off. Well, I poked around with the multimeter and found that the battery feed line was showing 16.5 volts!!! Whoa!!!
I then poked under the hood and found the same reading directly off the battery posts. Ok, so, new voltage regulator, right? Tried that first. Same voltage. It seems to start off ok, like at 14volts, then climb, at idle mind you, to 16-17 volts.
Tried wiggling all connections. Nothing. The engine wiring harness is a new reproduction unit, very nice quality. Tried unplugging the radio. Nada.
Any ideas? I'm at the end of my rope over here!
Thanks!!
First determine if the wiring and VR has control so to speak. To do that
1....Pull the green field wire off at the alternator. Briefly run engine, run RPM up and see if it charges, see if voltage goes up. voltage should stay at battery voltage
2....Hook above back up, remove connector at VR. Repeat test, again, "should not charge."
3....Make ABSOLUTELY certain VR is grounded. Scrape around bolt holes and rear of VR flange, mount with star lock washers. Some guys add a No10 ground wire from one of the bolts to the block
4...Next check for voltage drop, both in the wiring harness and ground side To do that..........
4A....With everything hooked up normal, backprobe the blue wire field connection on the alternator. Leave all wiring connected normal. With one meter probe on the blue wire, stab the other probe into the battery POSitive post. Do this with engine stopped, and key "in run." You are hoping for a very low reading, no more than .3V (3/10 of one volt) OR LESS.
If this reading is high, say 1/2 volt or more, this indicates a poor connection. The circuit "path" in a factory harness is battery......start relay......fuse link......through the bulkhead..........through the ammeter........to the ignition switch connector..........through the switch..........out the switch connector (on blue "ign 1") ..........back through the bulkhead on the blue...........and into the engine bay and ignition, VR, alternator field, etc
A high reading indicates a BAD connection in one of the above. Most likely is bulkhead connector terminals, the ignition switch connector, or right in the switch itself
4B...With everything connected normal, run engine to simulate "low to medium cruise" RPM. Do this test first with all loads off, and again with lights, heater, etc turned on.
Stab one meter probe into the battery NEG post. Stab the other into the VR mounting flange. As above you are looking for a low reading, the lower the better, and zero is perfect. If not, this means the VR is not "actually" grounded to the battery NET
If all the above checks out OK, it's a tossup..........either remove the battery and sub a known good one, or have the battery tested
Or.......replace the VR
