The curved, S shaped blades are the quietest . Think of modern submarine propeller. Straight blades like older helicopters, very noisy.
Since the entire purpose of the fan is to move air through the radiator, the fan should cover as much of the radiator core as possible. With that in mind, you should get as large of a fan as will fit on your radiator while still fitting under the hood. You will need to know how much clearance you have under the hood for the fan and any mounting supplies needed. It’s best to measure the area with the existing fan and shroud removed. This will tell you exactly what you have to work with.
Dual Radiator Fans or a Single Fan?
Usually a single fan is all you need; however, if you have added a much larger engine to your vehicle (and hopefully upgraded the radiator to compensate!) then you may want dual fans to maximize the amount of airflow. If you’re not having a problem with overheating, then stick with a single fan. If you have made significant upgrades to the engine or have heat problems, then dual fans will help provide the additional airflow needed.
What’s the Difference between Straight Fan Blades and “S” Shaped Fan Blades?
The fan blades come down to a difference in noise versus airflow. Straight blades maximize airflow but are also noisy. “S” shaped blades are quiet but don’t move as much air as the straight blade. Your choice here will come down to whether you want a quieter ride or need the most airflow. If overheating is already an issue, go with straight blades, otherwise go with whichever you prefer. Regardless of which blades you use, make sure the manufacturer balances the blades. If the blades aren’t balanced, it will cause additional stress and wear on the motor shortening its lifespan.
A pull fan sits behind the radiator between it and the engine. It causes air to be pulled through the radiator and has less impact on airflow at high speeds than a push fan does. Pull fans will provide more cooling than push fans will. The biggest determining factor on whether to use a pull fan or a push fan is the amount of room under the hood. When possible, use a pull fan, but if space limitations forbid this, then you will have to use a push fan
