Radiator clearance
Heating, Cooling & AC
  1. '73bird
    '73bird Well-Known Member
    515
    52
    Apr 26, 2016
    Phoenix, AZ
    Local Time:
    1:05 PM
    It seems my hood needs to be pressed down upon closing when I have my new champion radiator in. How much clearance do I need between the radiator cap and the hood? Should I redo the brackets? This is the radiator they said is for my year/model of car but seems the filler neck on the radiator is too long. Ideas?
  2. 747mopar
    747mopar FBBO Gold Member FBBO Gold Member
    12,856
    16582
    Oct 30, 2012
    ohio
    Local Time:
    3:05 PM
    Put a small ball of play doe on the cap and shut it lightly, that'll tell you where your at. If it's smashed to the cap you'll be lowering it.
  3. '73bird
    515
    52
    Apr 26, 2016
    Phoenix, AZ
    Local Time:
    1:05 PM
    Great idea but I don't have children so no play doe. What else could I use?
  4. mrsnicks
    mrsnicks Well-Known Member
    599
    191
    Feb 19, 2013
    cameron, nc
    Local Time:
    4:05 PM
    I have children. You can make your own.
    http://www.diynatural.com/homemade-playdough/
    I found that the Champion radiator for my car bottomed out on the lower radiator support.
    I have a power bulge hood so mine still closes, but sits higher than the original.
  5. '73bird
    515
    52
    Apr 26, 2016
    Phoenix, AZ
    Local Time:
    1:05 PM
    Bottomed out? What did you do to the brackets?
  6. mrsnicks
    599
    191
    Feb 19, 2013
    cameron, nc
    Local Time:
    4:05 PM
    I had to elongate the upper holes and I left it sitting on the bottom support. With a rubber strip in between.
  7. '73bird
    515
    52
    Apr 26, 2016
    Phoenix, AZ
    Local Time:
    1:05 PM
    Ok ty
  8. coloradodave
    coloradodave FBBO Gold Member FBBO Gold Member
    3,661
    3030
    Jun 1, 2011
    Lincoln, CA
    Local Time:
    1:05 PM
    Go to any hobby shop (or Target, Wal-Mart, etc.) and get a box of modeling clay. Works the same. Make sure there's a problem before you start modifying things.
    • Agree Agree x 1
    • Brewzer67
      Brewzer67 Well-Known Member
      364
      325
      Dec 20, 2015
      Menomonee Falls, WI
      Local Time:
      3:05 PM
      Make sure it isn't too close or you may discolor the paint. It happened on my hood. I had to put some lizard skin on the underside of the hood to keep it from getting any worse.
    • '73bird
      515
      52
      Apr 26, 2016
      Phoenix, AZ
      Local Time:
      1:05 PM
      I have about a 16th of an inch clearance on the driver's side of the cap moreso on the passenger side but the radiator it's self clears fine
    • rrTor-Red
      rrTor-Red FBBO Gold Member FBBO Gold Member
      2,041
      714
      Sep 1, 2010
      USA
      Local Time:
      3:05 PM
      Play doe. Cheaper than kids
    • '73bird
      515
      52
      Apr 26, 2016
      Phoenix, AZ
      Local Time:
      1:05 PM
      Ok got it all bolted in stuck a 3/4 inch block of baking clay (its soft before baked and .97 cents a block) on top and didn't get squished. So i presume its good to go. I cant find a lower radiator hose to fit my 1973 440 in a 1974 satellite. Bought the hayes thats called for and its too long. I cut it and it keeps kinking either under the water pump or before the radiator. When it finally stopped kinking it was too short. Any ideas?
    • idrivemopar
      idrivemopar Well-Known Member
      3,655
      2594
      Apr 30, 2012
      Colorado
      Local Time:
      2:05 PM
      With out seeing pictures, it sounds like you almost had it, as most radiator hoses have a bit extra length on the straight run, in this case would be the side going to the radiator not the pump end, and can be cut back.
    • '73bird
      515
      52
      Apr 26, 2016
      Phoenix, AZ
      Local Time:
      1:05 PM
      I got a new hose of the same kind and still kinked. I went through like 15 hoses trying to get one that will fit and nothing. I wonder if it has to do with the 440 coming out of a motorhome. So i ordered the radiator hose that fits a motorhome 440 and am waiting for it to come in. This is the biggest thing currently holding the satellite from running/driving
    • '73bird
      515
      52
      Apr 26, 2016
      Phoenix, AZ
      Local Time:
      1:05 PM
      Lol had to get a 1978 monaco 440 lower radiator hose to fit
    1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
      By continuing to use this site, you are consenting to our use of cookies.
