myfyn69
I'm the proud owner of a 1969 Plymouth Roadrunner clone that I have had since the early 90's the motor had a serious run in with about 3 gallons of water sitting inside the engine over the last winter. I loaned out a carb and thought i had sealed it off good, well I didn't so needless to say it does not run very well anymore. so I'm looking at getting the cost and parts list ready. She is a street/strip car. I want her to be able drive the 200 miles to Roseburg for a car show that we go to every year. but other then that she will be going to the strip. The motor right now has flat top pistons stock crank and heads, mallory 6a style box, msd coil, Mopar electronic distributor, Wiend tunnel ram with Edelbrock 1406 and 1407 carbs. Mopar 509 purple cam, clots double roller timing chain, big shot Nitrous up to 400 shot. we have a 200 shot with a Jacobs electronics Nitrous controller in it now. headman headers, 3" exhaust with a h pipe back to 40 series flow masters. 3000 stall converter 727 stock transmission, with 323 sure grip rearend. I have searched summit and different sites for kits but don't really understand what i should go for. as far as doing the work that's not problem but not really good at setting up the comb stuff, I'm fine with a bigger cam because now shes not going to be a daily driver, and was told I should get better rocker arms so I have looked at Harland Sharp S70015K - Harland Sharp Shaft Mount Roller Rockers and was told by some other Mopar guys these are worth the money, but then I'm lost as to either go the keith black route with pistons and h beam rods and new crank or just buy all stock replacement stuff as this motor ran 13's without the Nitrous before the water problem, any info would be great I will be stock piling info and parts till well after tax season before removing the engine and transmission. let me know if you need anymore info on the setup I tried to list what I have read to be of importance. also we also run 92 in the car unless it's going to the racetrack then it gets 110. the only other plan that may happen is I also have a hx-40 turbo from a dodge ram that might find its way onto the car though don't want that into the equation just in case it does not happen. I can just keep the boost low if I decide to install it. thanks James B
