Evan Frucht
Has anyone tried to slightly raise, or redo the parking brake cable configuration. I built and installed a dual exhaust system about a month ago, but would like to raise it an inch or so.
The parking brake cables are touching the tops of the exhaust pipes just barely and I'm worried this will cause trouble down the line.... such as heat from pipes causing them to weaken and eventually break, etc..
I would rather lift up the parking brake cables an inch (to get the clearance I want) rather than lower my exhaust... because it's already sort of low (5 1/2 inches from ground, about 2 inches lower than frame rails in center of wheelbase. I haven't been able to drive the car much to test it but, being that low, I'm thinking it may get damaged from going over potholes/bumps/garages and general unsavory road conditions... It may be just high enough to work but Its pushing it.
I wasn't able to go above the parking cables with my design without hitting driveshaft or being to close to floor. And am trying to make this work as is.
My first thought was simply to modify and lift up the cable guides that are welded under the floor pan, but that would (might?) put tension on cable and I'm not sure if it would work as planned.
Anyone tried something like this ?
