rakort
Good shape, totally serviceable as is or restore as you see fit, one of the trim faces has a small tweak on it that will easily be worked out. The second worse thing about them is the corrosion inside the reflector, but with careful cleaning and repainting it will be fine. The bulb sockets seems quite fine. Everything else about them is what I would call great. Has all the original hardware. A hard to find original set of OEM mopar parts.
$100
$100
