Ride Height adjustment - where?
Brakes, Steering & Suspension
  1. 70Bronco
    70Bronco Well-Known Member
    182
    51
    Aug 27, 2015
    Indiana
    Local Time:
    3:14 PM
    '66 Belvedere II.
    My ride height might be off. I think I measured the wrong points previously and now I'm all turned around and confused. The Service Manual photo is less than crystal clear. This may be ridiculously easy, but can somebody point on a photo and show me where I should be measuring?
    For the life of me, "adjusting blade" isn't matching anything I see.
  2. mopar 3 B
    mopar 3 B Well-Known Member
    10,263
    7696
    Aug 25, 2014
    Kingsville, MO
    Local Time:
    3:14 PM
    You have got to read the instructions.
  3. 70Bronco
    182
    51
    Aug 27, 2015
    Indiana
    Local Time:
    3:14 PM
    I'll clarify--using the "instructions," I'm having trouble determining where exactly the bottom of the adjusting blade is and the instruction photo isn't helping.
    ** Where is the A measurement? That is the bottom of what?
  4. WileERobby
    WileERobby Well-Known Member
    7,762
    10294
    Sep 15, 2009
    State of insanity
    Local Time:
    4:14 PM
    Where you're turning the bolt head. It's the curvature of the adjuster.
    • Agree Agree x 1
    • Officer Higgins
      Officer Higgins Well-Known Member
      3,811
      4879
      Jun 23, 2018
      Whiterville
      Local Time:
      4:14 PM
      Where is the ride height measurements for the rear?
    • 70Bronco
      182
      51
      Aug 27, 2015
      Indiana
      Local Time:
      3:14 PM
      So, it’s the bottom of the lower control arm in the middle, where the height adjusting bolt passes through?
    • WileERobby
      7,762
      10294
      Sep 15, 2009
      State of insanity
      Local Time:
      4:14 PM
      No, no, no. It's the adjuster. Look at the photo, it's perfectly clear.
    • 70Bronco
      182
      51
      Aug 27, 2015
      Indiana
      Local Time:
      3:14 PM
      Here? The bottom of the pivot shaft housing (for lack of a better term)?
      Not the best arrow—bear with me.
    • oldbee
      oldbee FBBO Gold Member FBBO Gold Member
      9,305
      9285
      Oct 15, 2011
      NE Ohio
      Local Time:
      4:14 PM
      Kinda,,, the movable blade close to ur arrow( adjuster bolt touches the outboard end of it).
    • 70Bronco
      182
      51
      Aug 27, 2015
      Indiana
      Local Time:
      3:14 PM
      Aha. (I hope) The piece in the middle:
    • oldbee
      9,305
      9285
      Oct 15, 2011
      NE Ohio
      Local Time:
      4:14 PM
      That’s ur measurement point per the FSM.
      • Thanks! Thanks! x 1
      • 70Bronco
        182
        51
        Aug 27, 2015
        Indiana
        Local Time:
        3:14 PM
        Thanks. You know, sometimes it’s the simplest thing. Geez.
      • WileERobby
        7,762
        10294
        Sep 15, 2009
        State of insanity
        Local Time:
        4:14 PM
        Bingo ! You measure the distance from the lowest point to the floor. Measure the lowest point of the steering arm/lower ball joint. Subtract the difference, will be your ride height t. I like 1 7/8".
        • Like Like x 1
        • 747mopar
          747mopar FBBO Gold Member FBBO Gold Member
          13,109
          17203
          Oct 30, 2012
          ohio
          Local Time:
          3:14 PM
          Guess I learned something today, I just adjusted mine to my liking and made them match lol.
          • Agree Agree x 1
          • oldbee
            9,305
            9285
            Oct 15, 2011
            NE Ohio
            Local Time:
            4:14 PM
            I’m gonna smack you Sat in Columbus!! Lol
            • Like Like x 1
            • 747mopar
              13,109
              17203
              Oct 30, 2012
              ohio
              Local Time:
              3:14 PM
              Take it easy on me big fella, I'm just a little guy but I am bringing a Sasquatch with me lol. In my defense my car is lowered 2" so the FSM adjustments don't apply.
              • Like Like x 1
              • 70Bronco
                182
                51
                Aug 27, 2015
                Indiana
                Local Time:
                3:14 PM
                The term “adjusting blade” had both me and my dad—who has farmed 50 years & seen a lot of repair manuals—perplexed. I figure somebody past/present/future had to be in the same spot & posted this.
                You raise another question:
                The repair manual Figure 2 photo shows the B measurement at the point of the knuckle directly below the lower ball joint, whereas the written instructions indicate “lowest point of steering knuckle arm” which would indicate the point where it meets the tie rod end. The height difference between those two points is considerable.
                I’m leaning toward the written instruction.
              • oldbee
                9,305
                9285
                Oct 15, 2011
                NE Ohio
                Local Time:
                4:14 PM
                I go low spot of ball joint. (Not grease fitting)
                • Agree Agree x 1
                • 64SF
                  64SF FBBO Gold Member FBBO Gold Member
                  855
                  569
                  Mar 16, 2011
                  Ocala,Florida
                  Local Time:
                  4:14 PM
                  I’m adjusting ride height as well...so I understand the difference btw the the two should be
                  1 7/8” .
                  • Agree Agree x 2
                  • oldbee
                    9,305
                    9285
                    Oct 15, 2011
                    NE Ohio
                    Local Time:
                    4:14 PM
                    Short story from 2 yrs ago on my alignment. Both places had drive-on frt end racks, 1st place after driving on said he couldn’t set ride height because of ramp being in the way(???). So I went to 2nd- he said no problem, knew how to do it. Let him take on test drive after he was done(big smile!). Both were older(50+), guess the first just didn’t want the hassle. Oh well.
                  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
                    By continuing to use this site, you are consenting to our use of cookies.
