RPM for a stock 1973 318 with a 430 inch cam?
General Mopar Tech Discussions
  1. mopar73dge
    mopar73dge Well-Known Member
    459
    172
    Jan 15, 2016
    Connecticut
    Local Time:
    7:24 PM
    no longer available
  2. yella71
    yella71 Well-Known Member
    335
    511
    Dec 18, 2018
    nj
    Local Time:
    7:24 PM
    ok here goes.....maximum RPM is just before it kicks a rod out the side of the block. Is that what you were looking for?
    • Like Like x 2
    • Agree Agree x 2
    • Ron H
      Ron H FBBO Gold Member FBBO Gold Member
      2,027
      1721
      Feb 29, 2016
      WI
      Local Time:
      6:24 PM
      So all the motor had 'done' was the cam? Shoulda been some other mods/machining done to accept the cam; but no clue as to the cam over stock..
      • Agree Agree x 2
      • BeatersRus
        BeatersRus Well-Known Member
        2,291
        2748
        May 31, 2015
        western ny on the hill
        Local Time:
        7:24 PM
        ty to the mod.
        to the op,we would need more info,cam size compression ratio etc etc.
        are they factory rockers,or aftermarket,etc etc.
        id say safe limits are 52-5500 rpm.
        screaming at 5k at around 70 in 2cnd sounds about right.
        make sure your kickdown is adjusted properly.
        • Agree Agree x 1
        • mopar73dge
          459
          172
          Jan 15, 2016
          Connecticut
          Local Time:
          7:24 PM
          Bored 30 over all stock valve springs etc. FBO IGNITION SYSTEM. thanks
          • Like Like x 1
          • Cranky
            Cranky Banned Staff Member FBBO Gold Member
            18,898
            14457
            Dec 4, 2009
            Pasa-getdown-dena Texas
            Local Time:
            6:24 PM
            Here's a combo with a 72 teen with 115k miles on it. .480 lift cam, MP springs rated for them but don't remember the number, heavy MP rockers, headers and associated parts to help it go 13.50 @ 102 mph shifting at 6200. It hasn't come apart....yet. Bottom end is stock and probably has 116k miles on it by now. But like BR said, 'safe' limits are probably no more than 5500 if you want it to live for awhile.
            • Agree Agree x 1
            • 69a100
              69a100 Well-Known Member
              6,638
              8855
              Aug 22, 2012
              The Real World
              Local Time:
              4:24 PM
              I'm sooooooooooooooooooo confused here? I take cranky is quoting something you said at one time here? How can a stock motor be bored .30 over? You may have stock type parts in your motor now, but it sounds like it's a rebuilt motor to me, therefore it's not stock from what I'm reading, even with the FBO ignition! I forgot my question. REV it until it explodes, then you'll have your answer! Good Luck!
            • 68Moparmaniac
              68Moparmaniac Well-Known Member
              631
              992
              Jan 18, 2019
              Utah
              Local Time:
              5:24 PM
              :rofl:
              Seriously, I think Cranky is pretty close to the RPM range of a stock motor w/aftermarket cam without knowing exactly what you have spinning around inside, induction/ exhaust/ ignition etc. all plays a roll. Engines that are able to live up in the higher RPM ranges have had extensive precision balancing work done, way above the basic balancing done at the factory.. some engines from the factory were better than others. Yella71 has a profound opinion that rings true, just sayin.
              • Like Like x 1
              • Darter6
                Darter6 FBBO Gold Member FBBO Gold Member
                3,395
                3317
                Dec 29, 2009
                Nevada
                Local Time:
                6:24 PM
                Cranky is right, One thing is rpm is judged by the quality of your valve springs. If the valve springs are factory stock, that 4800 rpm is just about where the stock springs will float the valves.
                • Like Like x 1
                • Agree Agree x 1
                • mopar73dge
                  459
                  172
                  Jan 15, 2016
                  Connecticut
                  Local Time:
                  7:24 PM
                  I meant 030 over and I am learning a lot about people good luck
                • Cranky
                  18,898
                  14457
                  Dec 4, 2009
                  Local Time:
                  6:24 PM
                  No, wasn't quoting anything he said at one time. Was just saying what a buddy and I did with a teen with better springs, HD rockers etc. And many write .30 over for .030 over. Not everyone is a machinist or knows decimals all that well or just don't think of adding a '0'. And things can be stock or nearly stock even if it's bored over and have an aftermarket ignition. It may not be pure stock but nearly stock. Does everyone have to be so literal....and nitpicky?
                  • Agree Agree x 2
                  • BeatersRus
                    2,291
                    2748
                    May 31, 2015
                    Local Time:
                    7:24 PM
                    im wondering why you have stock valvespings with the new cam?
                    am i the only one?
                    also,with a stock valvetrain,
                    you are likely going to run into valve float before you reach max rpm.
                    • Agree Agree x 1
                    • Cranky
                      18,898
                      14457
                      Dec 4, 2009
                      Local Time:
                      6:24 PM
                    • 1967coronet
                      1967coronet FBBO Gold Member FBBO Gold Member
                      1,039
                      1205
                      Jun 19, 2014
                      Iowa
                      Local Time:
                      6:24 PM
                      I may be the only one here that thinks stock Mopar springs in good shape should be ok on a .430 lift cam.
                      Im no expert at all but that cant be to much more lift than a stock 340 spec /style mopar cam.
                      Rpms I would say 5000/5500 also , its prob just making noise instead of power at that point anyway.
                      • Agree Agree x 1
                      • yella71
                        335
                        511
                        Dec 18, 2018
                        nj
                        Local Time:
                        7:24 PM
                        stock 318 springs are not the same as stock 340 springs. 340 springs are higher rate springs. your thoughts are not far off the mark tho as a 430 lift cam if its just a mild hydro is not very aggressive. but if the best performance is what your after the springs need to match the cam specs. why any one hotrods a 318 is beyond me, especialy with 318 heads. the small port will cut off air flow at a low RPM . I guess I just think things out first then get the right stuff to have the results im after. if your after power you need parts that will make power. seems like a waste of time messing with stuff that will only make limited power beyond their capability
                        • Like Like x 1
                        • Cranky
                          18,898
                          14457
                          Dec 4, 2009
                          Local Time:
                          6:24 PM
                          In our case we were just messing around with junk that we both had laying around our garages. The teen was still in good shape and pulled down even numbers after a compression check so we started throwing stuff at it. We weren't planning on doing a pocket job to the 360 heads...which only lowers CR on a teen. The combination of parts were way off and the converter was still stock but the engine responded well. Everyone that came by our pit area asked if it was a 340 or a 360 and none of them believe it was a teen but no one wanted to lay any money on the fender to see. Thing is, it's easy to look at the numbers on the block lol. The car was pretty dead off the line cutting a 2.2 60 foot but it started pulling really hard at 3000 on up. Surprised both of us! People always say that there's no replacement for displacement but you can make a little engine think it's bigger just by flowing more air through it. There are still a lot of racers in Comp Eliminator running crazy sounding numbers with even crazier little engines. My first introduction into the itty bitty engine committee was from a guy at work that was running a 56 all steel shoebox Chevy with a 265 launching at 9k and shifting at 9500! The car was running low 11's back in the mid 80's in SS/O. IIRC, he and his buddy were trying to not run faster than 11.50's or 60's so they didn't CIC'ed in competition. They were also running a 5 speed but could only use 3 gears according to the rules at the time.
                          • Like Like x 1
                          • yella71
                            335
                            511
                            Dec 18, 2018
                            nj
                            Local Time:
                            7:24 PM
                            Ok Ill go with that If its free its for me. Im not saying you cant make power with small cubes just you need to move air through it. like you said fool it into thinking its bigger. If you put heads with bigger ports that helps but compression is key. its nice to see you know that just putting 360 heads on will drop compression. what is needed is big ports small chamber and as said LOTS of RPM. Oh and lots of money. get some gears in the rear and some tighter valve springs so you can rev that teen to 6500 or better then run it some more
                            • Agree Agree x 1
                            • 69a100
                              6,638
                              8855
                              Aug 22, 2012
                              The Real World
                              Local Time:
                              4:24 PM
                              You want to play semantics? We can play semantics all day long! In the end there's a BIG difference between factory stock and rebuilt, or even "rebuilt" stock for that matter, they're not the same!!!! Never have and never will!
                              • Agree Agree x 1
                              • Cranky
                                18,898
                                14457
                                Dec 4, 2009
                                Local Time:
                                6:24 PM
                                Got it going 13.80 with 4.10's on ET streets but it was spinning them when it hit 2nd. Couldn't heat them up since the car didn't have ANY low end lol....so, I had a pair of 29" slicks but that would kill the 4.10's so in went a 4.88 and that's when the 13.50 popped up. The car was crossing around 5200 with the 4.10's anyways. Yeah, we knew the 360 heads would lower the CR but that's all we hand and he didn't want to spend time on a 318 head and the 360 heads would eventually find their way onto a 340.
                                • Like Like x 1
                                • Cranky
                                  18,898
                                  14457
                                  Dec 4, 2009
                                  Local Time:
                                  6:24 PM
                                  If you think I'm playing....that's fine, but I'm no purist either. Rebuilt to stock specs even with an overbore.......rebuilt stock to me. Now rebuilt with highly modified stock heads isn't stock to me anymore.
                                1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
                                  By continuing to use this site, you are consenting to our use of cookies.
