Metwurst
New Member
I have just installed a stroker 408 using the A904 that was behind the original 318. The motor is a new, the converter is a PTC 2200 stall unit. The trans has been left untouched, save for a new pan, gasket and filter. After installing the driveshaft I tried to push the car into another position in the garage, but it would not move an inch. I moved the shifter through all gears, still the car would not move, and it appears it is stuck in Park. Even when it was placed on a hoist and checked underneath for any obstructions, still no movement. I had to remove the driveshaft to push it around the garage again.
Any thoughts or suggestions would be greatly appreciated.
