Ok.......I am digging into this fine tuning bigtime on my 500" stroked 440 I have. I have an aftermarket Accel distributor in it much like the MP electronic distributor. I have the advance plate set at a 15 degree timing curve. My initial at idle is 20 degrees and total is 35 degrees all in around 2800 to 3000 RPM. My question is hooking up the vacuum advance. It runs alot better with it hooked up. Now here is the problem. It isn't doing jack at idle. When I rev it up it starts advancing the timing with the vacuum hooked up which is normal. I have an adjustable vacuum canister on it but that doesn't seem to do what they say. Everyone says that the amount that the vacuum will add to the timing is fixed and that adjuster just determines at what vacuum it starts adding the timing. Well that's a crock on this one because adjusting that canister with the allen adjusts how much total timing with vacuum is added. I have read multiple sources saying around 50-55 degrees total vacuum timing is about where you wanna be. Well my motor pulls about 12 in/mg vacuum at an idle even with my large cam and it doesn't change the timing there whether its plugged into the vacuum advance or not. I am not sure why it won't activate the canister unless it needs alot more to start opening it???? Any thoughts? Maybe the canister isn't designed to start opening until there is more vacuum??? Just weird because they swear that adjusting the allen changes the vacuum in which it opens but I am reading that in some other canisters the allen controls the amount of timing added and the opening point is fixed.......Insight?
