440 6-pack, running well. I am about to replace the vacuum diaphragm springs on the two outer carbs, but before I did anything I performed the very scientific 'suck test' to make sure the diaphragms were responding as they should. Both move when I suck on the tubing, but I can hear air escaping and the vacuum doesn't hold. Is this normal? Is there some path inside the outer carbs that 'leaks' vacuum? It's not the tube and it's not the connection to the carb, and I tightened all the screws around the diaphragms, no change. Should this be a really tight vacuum seal or is some leakage normal?
I also noticed that pulling vacuum on one carb moves both diaphrams (of course it does, they are connected on the other side...) but I never knew that was the way it worked.
