Ed Martin
Please help. This is related to my post on October 1, 2019. This is still driving me crazy!
Summary: replaced carb, coil, cap, rotor, ECU, plugs, 2-pin ballast resistor, checked reluctor gap at 0.010-0.012". Now can get spark at coil and end of one plug wire (just checked one), but it only cranks (no fire). I can see accel pump squirting gas from under the hood and choke closes all the way after hitting the pedal one time. I assume the vacuum pull-off is working since carb is new (but cannot verify since it will not start), but did try screw driver to keep choke open a small amount. I have driven it 2-3 months ago with new carb -- but not now. Here's what I get: 10.6 V at + coil in start, 7.4 V at + coil in run, 12.23 V at batt switch off, and 11.91 V at batt in run. So shouldn't 10.6 V be able to start it up … because when I get a spark at plug wire (in run position) by jumping batt power across starter relay to crank it (instead of using the ign switch - with no helper), the resulting spark I see is using the 7.4 V at + coil because the ign switch terminal is not sending the 10.6 V to coil as it would be doing if I used the key to start it? So if I can get a spark at 7.4 V, I should be able to get a spark at 10.6 V (when I use the key)! I checked and rechecked firing order (as I did have the wires disconnected when replacing dist cap). It seems there is only one way to attach dist cap with the notch in cap to match housing prong. I'm using 1-8-4-3-6-5-7-2 counter clockwise with #1 wire to the first connection clockwise 180 degrees from the notch in cap. If this makes sense.
