Franks500
Hi Everyone,
Picked up a 67 Coronet 500 383 in May. Drove around 40 miles and the car spun a rod bearing. Had entire engine rebuilt - replaced crank, pistons, bored .030 over, larger exhaust valves and so on. Got the car back together around two weeks ago - lots of minor issues to address but ran great - good oil pressure for about 200 miles.
Took the car to work yesterday - around 60 miles round trip, noticed what sounded like a fan belt squeak on the way home. Removed fan and power steering belt, squeak remained.
Did some research and checked the starter bolts and flex plate bolts - all fine.
Started the car - all fine until completely warmed up, squeal is back.
First thing I dd was remove the valve covers and noticed the inside of the cover was completely dry. Started the car - expected a mess but only saw oil on the exhaust and intake closest to the firewall - both sides.
Removed rocker arms from both sides- don't have a priming tool so cranked engine with the starter. Not sure but it looks like oil should be supplied from two passages on each head. Only had oil squirting from the passage closest to the firewall on each side.
Spoke to the machine shop that did the work and ensured me that the cam bearings were installed correctly.
So, my question(s) is - could I have spun a cam bearing - or other bearing? Oil pressure is approx 45 psi. Could there be a blockage to the other passages or does the oil only pass through two of them? Could this cause the belt like squealing that I hear? Don't think the head gasket could be installed incorrectly but possible - blocking a passage?
Any help with this is greatly appreciated!! Thanks!
