max340
Hey guys. I haven't started my 440 in two years since an accident took it off the road. What's a good start up procedure? Good to go now or should I pull the distributor and pre oil? Thanks
I think I'll just pull the plugs and shoot some oil in each and pull the coil wire. Thanks!! giddyup!Not a bad idea to pre-lube. Use a fresh filter and oil. Also not a bad idea to pull the plugs and give each cylinder a squirt of atf or oil and turn it over a few times by hand.
