Steering wheel removal
kournikova462
8:28 AM
Salt Lake City
Hey guys
im restoring my 67 Belve and i want to remove the steering wheel.... how do i go about this
i think the plastic center cap pops off but i dont want to damage it
anyone have any tips
thanks
JHo
Welcome. What wheel/horn ring does it have? Post a pic if you can. Should be an easy thing
Thanks for the kind welcome
here is a pic of the wheel
thanks for any and all help
JHo
Cool....that's the wheel/horn ring I was betting on. The center piece with the Plymouth emblem is only about 1/2" thick and will twist off...counter clockwise I believe. Then there should be (I think) 3 phillips head screws retaining the horn ring and the switch itself. Get those out of the way and you're set to use a puller. A note....run the big nut up so the shaft is flush with the top of the nut. Gives a bigger footing for the puller and won't damage the shaft if you have to break out a #3 knockrometer for assistance lol
