Recently performed a cylinder compression test on my stock 1964 383/4 barrel motor, wondering what "average" numbers should be, and what others have seen on similiar motors? Thanks
Never checked a 64 but a healthy engine shouldn't vary more than 10% between any cylinder and the less it varies the better but according to a Motor's Repair Manual it should be 160 for a 64 model year 4 bbl engine. Of course this can be different if the engine has ever been rebuilt or has had a different cam installed or is worn...
I just checked my 1965 383 this spring, no problems but I just wanted to see.
High reading was 132, lowest was 125 all others were in between. seems to run just fine, no blow by ect.
