I'm sure the pan will bolt to a 383 if it fits a 440/426. Will the pickup and the K-frame be compatible? Any oil pan change you should re-calibrate your dip stick level.
looks to be the basic '70 6pak/hemi pan. will for sure fit 66-70 b-body and e-bodies. the only issue i've had with those repop pan-pick up combos is the pick up being too long.
