Super shifter in a 64?
1962 - 1965 Mopars
  1. Steve009
    Steve009 FBBO Gold Member FBBO Gold Member
    665
    572
    Aug 2, 2016
    Ottawa
    Local Time:
    4:23 AM
    I have been trying to find a hurst super shifter for my 64 Plymouth sf. All I can find are 1965+ and most are “competition plus” models. Do they make super shifters with the straight linkage rods for 1964 b bodies? My linkage is all worn out and I figured it’s time to upgrade. A link or advice would be much appreciated. I’d also not like to use the short shifter rod that I see in some of the catalogues and swap to the longer stock hurst shifter rod. Is that as simple as undoing the two bolts and swapping?
  2. HEMI-ITIS
    HEMI-ITIS STREETER on LI FBBO Gold Member
    11,608
    13769
    Dec 14, 2008
    Long Island,New York
    Local Time:
    4:23 AM
    I'll NEVER give up my PB shifter!!
    • Like Like x 4
    • rarefish
      rarefish Well-Known Member
      341
      146
      Jul 9, 2013
      NY
      Local Time:
      4:23 AM
    • Auto Teach
      Auto Teach Well-Known Member
      133
      37
      Jul 29, 2012
      New England
      Local Time:
      4:23 AM
      • Agree Agree x 2
      • Thanks! Thanks! x 1
      • Fran Blacker
        Fran Blacker FBBO Gold Member FBBO Gold Member
        7,839
        7436
        Sep 23, 2016
        Connecticut
        Local Time:
        4:23 AM
        Is the S/S the one that has a bracket that moves shifter up a to the back? Seen guy use heim joints, steel hydraulic tubing with nuts welded on each end.
        • Agree Agree x 1
        • Steve009
          665
          572
          Aug 2, 2016
          Ottawa
          Local Time:
          4:23 AM
        • Steve009
          665
          572
          Aug 2, 2016
          Ottawa
          Local Time:
          4:23 AM
          i really dont know. all i know is the super shifters come with the straight rods and all the competition plus ones i can find are curved. I cant find a super shifter setup for a 64 with straight rods.
        • Fran Blacker
          7,839
          7436
          Sep 23, 2016
          Connecticut
          Local Time:
          4:23 AM
        • Steve009
          665
          572
          Aug 2, 2016
          Ottawa
          Local Time:
          4:23 AM
          • Agree Agree x 1
          • rarefish
            341
            146
            Jul 9, 2013
            NY
            Local Time:
            4:23 AM
            • Thanks! Thanks! x 2
            • Agree Agree x 1
            • Fran Blacker
              7,839
              7436
              Sep 23, 2016
              Connecticut
              Local Time:
              4:23 AM
              Really didn't look at shifter wanted to show bracket. Seen shifter with bracket and with straight rods $600 and up. Think buying bracket and making your own rods easier. If you want rev- lockout you need the right shifter (as you said) or an add on kit. Those add on kits NOS on ebay are getting $300+. To make one yourself wouldn't be to hard?? Wouldn't be a nice unless your a good at fabrication.
            • cryplydog
              cryplydog FBBO Gold Member FBBO Gold Member
              1,478
              1222
              Apr 13, 2013
              NE, MO.,
              Local Time:
              3:23 AM
              009, you can pickup quite a bit of geometry buy working your clutch and shifter linkage by modifying all parts involved and buy taking the slop out of all parts, cutting and welding are required, I shorten the clutch pedal about an inch or less to minamize the throw distance and I modify the torque arm to be 90* to the upper clutch rod and lower clutch rod 90* also. Have a helper actuate the clutch a few times to find center of the throw and saw cut the shift fork to find mid position of the clutch throw to make it 90* also and weld it back together The shifter is the same, first off I shorten my shifter handle a little and cut/reweld/reshape it to fit my body and arm position and you can also space your shifter body further off center a little towards the driver as well as raise the shifter body some to further shorten the shifter length. the shift levers on the trans need to be correct p/n and not all wallered out. You can also get the Hurst bushings on both ends of the shift rods. Making shift rods that are more strait with heim joints on the ends as well as spacing the shifter rods in and or out for a straight/lateral movement. These old units can take a lot of mods and work way better than factory settings. Its all about XYZ movement and or parallel and perpendicular adherence. With shifter in neutral you should be 90* on the trans levers as well as the shifter levers. clean up all extra length of rods levers etc. that's not needed. And a lot of 30 wt. and good hardware including rebuild the torque arm bushings. Another place to pick up some positive geo. is that rubbery bushing/damper system at the end of the lower clutch rod, I take all of that crap off to reduce yet more wasted movement but you need some end play here too. Not to big of deal, just a little time and ingineuity. Makes a heck of a difference. In my world I make a lot modifications I guess.
              • Like Like x 1
              • Ron H
                Ron H FBBO Gold Member FBBO Gold Member
                2,583
                2391
                Feb 29, 2016
                WI
                Local Time:
                3:23 AM
                I'm a PB fan too having the stock set up in my '63. Wouldn't give it up much as I like a 4-speed manual. Remembering the drag legends of the day when buttons were around and a ride in my Uncle's new '64 one night as he ran through the PB's was a hook for me to someday have an old Mopar with this set up. Have had my Plymouth 23 years now.
                • Agree Agree x 2
                • Steve009
                  665
                  572
                  Aug 2, 2016
                  Ottawa
                  Local Time:
                  4:23 AM
                  I have to say I’m am no where near a good enough welder/fabricator for this kind of work. Would love to learn one day but cutting and rewelding would end up a disaster for me.
                • ckessel
                  ckessel Well-Known Member
                  890
                  755
                  Apr 23, 2015
                  Los Osos Ca.
                  Local Time:
                  1:23 AM
                  Just a thought for you, if you come across a Mr. Gasket shifter latch onto it for your car. I had one of those on my Duster in the late 70's when I swapped the 4 speed in to replace the 3. Mr. G's unit were a better design, to me and some others, plus they used 7/16" straight rods, except for reverse, that were way better than the 3/8" units on Hurst's stuff.
                • Steve009
                  665
                  572
                  Aug 2, 2016
                  Ottawa
                  Local Time:
                  4:23 AM
                  You think they would also use straight rods for the b body? Similar to your Duster?
                • ckessel
                  890
                  755
                  Apr 23, 2015
                  Los Osos Ca.
                  Local Time:
                  1:23 AM
                  Think so but its been a long time since I've seen one.
                • mopar 3 B
                  mopar 3 B Well-Known Member
                  9,107
                  6443
                  Aug 25, 2014
                  Kingsville, MO
                  Local Time:
                  3:23 AM
                • cryplydog
                  1,478
                  1222
                  Apr 13, 2013
                  NE, MO.,
                  Local Time:
                  3:23 AM
                  I think they started in about mid/late 1964.
                • mopar 3 B
                  9,107
                  6443
                  Aug 25, 2014
                  Kingsville, MO
                  Local Time:
                  3:23 AM
                  A few of the Ram Charge cars and very few production car used the 4 spd with floor shifter in 64. I don't think a Chrysler trans was used in any of them. Am I wrong?
                1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
                  By continuing to use this site, you are consenting to our use of cookies.
