Tach help needed.
Electrical & Ignition
  1. bee71
    bee71 Well-Known Member
    905
    484
    Aug 10, 2012
    St. Augustine, FL
    Local Time:
    6:34 AM
    Recently the tach on my 71 Bee started to not work on start-up. Then after driving for a while it would work. It always has been 1500 rpms too high when working but the intermittent has me stumped. Also, previously when shut down the needle would hover at 500 rpm. Now sometimes when I get in the car, I noticed the needle parked at just under 0. When it is like that I find that that is when it won't work on start-up. Do I have a current drain when the needle is at 500 rpm after shut-off? Is the blue wire that is attached to a clip and protruding stud coming out of the engine side of the firewall and outer fuseblock the tach wire?
  2. A383Wing
    A383Wing Well-Known Member
    2,356
    680
    Dec 27, 2008
    Somewhere
    Local Time:
    3:34 AM
    if you did nothing to car or tach between it working right back then and now, sounds like a resistor or capacitor inside has gone bad..time for a rebuild or new circuit board inside
  3. The Horvaths
    The Horvaths Well-Known Member
    203
    57
    Sep 2, 2014
    DFW
    Local Time:
    5:34 AM
    At the very least, it may be time for a tech to check it out.
  4. dangina
    dangina Well-Known Member
    655
    156
    Aug 17, 2010
    lethbridge
    Local Time:
    4:34 AM
    • Like Like x 1
    • The Horvaths
      203
      57
      Sep 2, 2014
      DFW
      Local Time:
      5:34 AM
      Good info, dangina.
      If you're an electronics nerd, like me, it's easy to accurately calibrate a (working) tach with a (12V) pulse generator. For an eight cylinder, it's Hz/8*60.
    1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
      By continuing to use this site, you are consenting to our use of cookies.
