So what was your most current weight minus driver before the engine issue? Are you expecting any weight change with the new mill?
Travis…
EDIT…I guess that’s DVW that windowed his block and not you. Too many old black race cars on here. Regardless, do you have a current weight and broad specs on the car?
Yes, unfortunately, after DVW windowed his block, it was indeed lighter. No pun intended and thank the heavens that he is safe.
This car's weight without driver is 2990 Lbs with a few gallons in the tank. I expect a big plummet of 20 pounds more or less once I get a chance to install the new K frame and trim off some gussets from the block.
Other little do-dags here and there will net another few pounds.
In a real world, I'd be happy to trim the car down to the upper 2800 Lbs while staying ALL METAL and then I think that would be the most reduction obtainable.
Is it possible to land at a rock bottom 2800 Lb goal? probably not.
On the other hand, taking off 100 Lbs from this point of 2990 to land at 2890 is probably realistic, but it's going to be super hard.
As a note, the 1965 A/FX 10"-15" cars were delivered at 2800 Lbs with the extensive use of fiberglass, plexiglass and aluminum and only after their steel bodies were reduced to paper mache at the chemical milling plant.
Low weight B-bodies? Sure! Anyone can do this if they look at everything, everywhere .........with common sense.
Mopar John, who pilots the "Bitter Lime" GTX can fill you in on this.
PS: an aluminum block is not in the cards.
