Thinner or Weaker Shift Column Clip
mrmolding
5:56 AM
CA
Does anyone know the part number or replacement part for the thinner circle wire clip that goes from the steering column tube to the transmission linkage? I tried using the clips for the manual shift rod linkage but they are thicker and stronger than the others in the column linkage. Below is the stronger clip, need the thinner one…
Any help is welcomed!
Looks like I figured it out. There is a clip kit that brewers and roseville both have for column interlock that have smaller but similar clips to the hurst clip I took above. In case anyone has a similar issue and finds this thread...the clip I'm mentioning is highlighted in the diagram and the similar hurst clips are too large. Hopefully the clips in the second picture will work...
