1. Rob Vaughn
    Rob Vaughn Well-Known Member
    87
    28
    Apr 11, 2016
    Local Time:
    5:20 PM
    My car was kinda built around the 345 55 15 bf Goodrich drag radial but now it appears this size is no longer available. I would like to see what people are running with mini tubs. I want a tall and wide tire to fill the wheel well . 295s seem to be my only option anyone got a picture. Mine are 30 inches tall with a 14.6 section width. 20200420_102800.jpg
  2. 33 IMP
    33 IMP FBBO Gold Member FBBO Gold Member
    3,941
    5023
    Dec 21, 2017
    taxifornia,soon 2b Arizona.
    Local Time:
    2:20 PM
    Jegs says M&H drag radials 390-45x15 are 29.5 tall, 14.8 section width on a 12" rim, and 12.1 on the ground. Both nitro and M/T make 325x50 drag radials, a little smaller and shorter than yours.
    If you have a 12" rim, the 390 should be less than an 1/8 wider to either side.
    They aren't cheap.
    Hoosier makes a quick time pro, 29-14.5x15 that is close, and $150 cheaper per tire, but that is basically a stiff wall bias slick with grooves. Great for a street racer, lousy for a driver.
  3. Rob Vaughn
    87
    28
    Apr 11, 2016
    Local Time:
    5:20 PM
  4. Rob Vaughn
    87
    28
    Apr 11, 2016
    Local Time:
    5:20 PM
    Yeah I seen all of those, probably gonna have to go with thos M&H ugh!
    Hoosier are bias I have radials on the front and the Mickeys are about right but 11 inch wide is the max, the 315 60 15 is closer than any tire but can only fit 11inch wide rims, why? Don't know
  5. 33 IMP
    3,941
    5023
    Dec 21, 2017
    Local Time:
    2:20 PM
    I don't know either, mine are on a twelve inch rim, and I've seen them on fourteens. Probably Mickey legally cya. The 315s have a DOT, but they also say "not for highway use" in big letters. Street legal? Only the officer that stops you will know. Lol. (Left, in the pic.)
  6. Rob Vaughn
    87
    28
    Apr 11, 2016
    Local Time:
    5:20 PM
  7. Rob Vaughn
    87
    28
    Apr 11, 2016
    Local Time:
    5:20 PM
    Really? They seem ok at high speeds?
    I think I might just do that to!
  8. 33 IMP
    3,941
    5023
    Dec 21, 2017
    Local Time:
    2:20 PM
    Guys with those tires are in the low 4 seconds at 170 mph in the eighth mile, on fourteen inch rims. They're pretty stable
    Edit: I think the record for a 315 might be in the threes, at over 200 mph.
  9. 6PKRTSE
    6PKRTSE Well-Known Member
    1,555
    2153
    Nov 15, 2010
    Motor City
    Local Time:
    4:20 PM
    I have 315''s on 12" wide wheels. They measure 30" x 15.5" on the section width when mounted.
  10. Rob Vaughn
    87
    28
    Apr 11, 2016
    Local Time:
    5:20 PM
  11. Rob Vaughn
    87
    28
    Apr 11, 2016
    Local Time:
    5:20 PM
    Well that looks good!
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
