Todds Restorations
Skatpak
2:57 AM
Mn
I was asked to share what I do on this forum as some are not on FB.
Todds Restorations specializes in 66-67 Chargers.
Repair, restore, Rebuild, Replace the gauges.
Replace the gauge faces with new faces.
Repair the El lighting.
Repair, rebuild the power pack.
Repair, replace, repaint the needles.
Upgrade the voltage limiter and disable the points limiter.
Repair, rebuild restore the clocks.
Repair, restore the shift indicator.
Replace lenses- depending on availability at the time, original or aftermarket.
Replace the bezel- original ac or non-ac- depends on availability at the time.
Calibrate gauges to Stewert Warner specs.
Clean/lube/adjust/ calibrate the speedo movement and the tach movement.
Upgrade the tach board with modern electronics from RTE. 66 and 67
Calibrate the new tach boards.
Specializing in the lighting system diagnosis and repair
Rebuild/restore the heater box ac or non ac including heater core and evaporator core repair/replacement.
Specializing in locating parts.
Contact me for prices and needs.
Todds Restorations
Todd
ph# 763-377-0972
email [email protected]
Pm me
fully licensed and registered.
Ghostrider 67
Jack Stand Racer #6..and proud of it!
3:57 AM
Salisbury, Vermont
Todds Restorations
Todd
ph# 763-377-0972
Pm me
Good to know! Thanks.
