Virg464
Do you run OEM style lines with headers? I have a 66 coronet and I'm trying to install a set of pre-bent SS lines but they interfere with the headers (driver side). I tried putting the headers in with the lines installed - No Go, tried to install the lines with the headers mounted - No Go. So I'm wondering if the lines need to be replaced due to the headers or maybe the lines that I have aren't bent correctly for this application (400 motor/727 trans/Big Block headers, hooker I think)?
Not sure who manufactured the lines but they fit without the headers. They are bent out around the bell housing area, then back in past the area wear the starter will be and they tuck up next to the oil pan rail and pass by the motor mount. The interference is right where the header tubes drop down to the collector and where the starter will sit. The lines hang just above the center link of the steering linkage with both ends tightened (without any hanger/clips). That seems a little odd to me.
Anyone got a pick of how their lines are routed in that area with headers? Would be much appreciated.
