kaj750
In case anyone is searching for R&R of an oil pan for a 440, I’ll post my experience here. This is me “figuring it out on your own and learning by making mistakes”.
First: I had trouble pulling the oil pan off. The FSM states to rotate the pan counter-clockwise but that didn’t work for me. I rotated the pan as far as humanly possible, but no luck.
After a lot of pulling and twisting, the oil pickup rotated around, clockwise, which enabled me to FINALLY drop the pan. The fact that it moved is obviously not great. I also happened to notice there was no windage tray. Thirdly, I found a spot on the pickup where it looks like something knocked into it. Interesting. Engine previously showed no sign of oil starvation/lack of pressure.
To test a theory, I tried to install the pan with the pickup in place. There is just no way. I can’t turn the pan far enough CCW to clear the pickup. I then put the pickup where it was when the pan came off. The pan went on with only a bit of hassle. I then reattempted the same with a windage tray in place. The pickup would not rotate enough to get the pan on, as the tray blocked the last bit of rotation.
What I think I learned from all of this is that the original owner installed the pan with the pickup rotated CW and no windage tray, to allow the pickup to turn far enough to clear the baffle. This left it far enough over that the crank had to self-clearance and knocked the pick up out of the way.
What this leaves me with is a pickup that is not completely tight but doesn’t seem to have a problem functioning and a pan that won’t go on unless the pickup is loose. With all my test fitting and experimenting (I was bored, since I can’t put the car back together), the only way this all worked was to:
So, since I can’t do any of that, I guess what I’ll actually be doing is:
I’ll update as I go. Hopefully this eventually provides insight to someone of what NOT to do while messing with an oil pan LOL.
To be continued….
- Cut a relief in an old windage tray to allow the pickup to rotate enough to get the pan on.
- Place the modded tray and pan into place.
- Wiggle everything into place – effectively moving the pickup counterclockwise to clear the crank and be in the bottom of the pan.
- Hope that putting everything back the way it was (incorrectly) holds up the same way I did before.
- Lifting or lowering the engine enough to give me the room needed to pull the oil pick up out (it hits an engine mount, so can’t be removed),
- Tape it up, then reinstall correctly.
- While I have the clearance, I will hopefully have enough room to rotate the oil pan enough to get it installed.
- Hope I NEVER have to replace the oil pan again.
To be continued….
