U-Joint Replacement
bulldog
2:50 PM
Ontario, Canada
Hey Guys,
I have yet another question. I found out my u-joints were bad, so I pulled the driveshaft and removed both u- joints. My question is when installing the new one's should I install the new one on the yoke first and then attach the yoke to the driveshaft or on the shaft first then on the yoke. Keep in mind that the 67 Coronet, has a very heavy weight on the front of the driveshaft.
It really doesn't matter. Just be careful with what ever end you start with when you work on the other end
