Must be a bugger getting them back off?I used a thin bead of Ultra Black on both sides of the gasket and no leaks whatsoever.
*some* engines don't need their valvecovers on and off like a hookers panties!!Must be a bugger getting them back off?
Would you use the same on the transmission pan gasket?I used a thin bead of Ultra Black on both sides of the gasket and no leaks whatsoever.
On that I use the Mopar rigid reusable gasket.Would you use the same on the transmission pan gasket?
Haven't needed to yet. Only been 2k since rebuild.Must be a bugger getting them back off?
Couldn't agree more.With the 68-69 hp manifolds the cork doesn't last very long. 2 years and they get dried above the exhaust ports. I can't recommend cork.
