Vinegar and water rust kill then prep for paint ?
Cranky
Banned Henchman #27
Staff member
6:18 AM
Pasadena, Texas
I think someone mentioned this awhile back but haven't been able to find the thread after doing several searches. Anyways, I removed all the paint from my car years ago and then sprayed primer on most of the car which is actually pretty much still there. It will be removed before a reprime. Question is, after removing the surface rust that has showed up with vinegar and water, what is good to use as a final treatment before applying primer? And I'm thinking about using epoxy primer when the metal prep is done. A buddy mentioned Rust Kon which seems to only come in rattle can but that might do ok for spot work....?
I use the PPG Metal Wash DX579 then the conditioner DX520. Works well, but you should paint/prime shortly afterwards. It will leave a fine zinc coat. I Pretty much always use the DP40 Epoxy Primer afterwards.
an old "How to" thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/262049-metal-conditioning-epoxy-priming-101-a.html
Also used the picklex 20 several times with no issues thus far. Here's a little comparison chart if you want to take a look at several different brands capabilities/limits.
http://picklex20.com/compare-metal-prep/
