Not correct. Stock bolts did not use washers. Aftermarket such as ARP and others can have washers on bolts as well as the stud nuts. Poster did not say what bolts he bought. That's why I said no unless they are special.No. Washers are for studs not head bolts
I was answering the OP not you.Not correct. Stock bolts did not use washers. Aftermarket such as ARP and others can have washers on bolts as well as the stud nuts. Poster did not say what bolts he bought. That's why I said no unless they are special.
You should start your own thread for that information.does anyone know the length of intake manifolds bolts on 426 hemi
So can factory bolts be reused with aluminium heads?Aluminum heads require washers with the bolts.
What heads? What does the head manufacturer recommend?So can factory bolts be reused with aluminium heads?
They are Edelbrock 5090 heads. Edelbrock recommends "High quality head bolts with hardened washers". Could hardened washers be added with the factory bolts?What heads? What does the head manufacturer recommend?
Just get the ARPs. For that head. Generally the big factory bolt head doesn't work in the bolt hole pocket anyway.They are Edelbrock 5090 heads. Edelbrock recommends "High quality head bolts with hardened washers". Could hardened washers be added with the factory bolts?
Would not be recommended. Just get the right bolts.They are Edelbrock 5090 heads. Edelbrock recommends "High quality head bolts with hardened washers". Could hardened washers be added with the factory bolts?
You did get replies Lol.Thanks for all of the responses.
I didn't think they needed washers but I thought that I would ask the experts.
