- 11:51 PM
- Jan 29, 2018
- Midland Ontario, Canada
Sucks and blows...
Uhhh, secondary squirters DO push something. What isn't needed or used ends up in the oil, the cylinder walls, the exhaust stream, the air we breathe...A carb doesn't push anything. There's just more fuel available " on demand".
I see your angle. But the split second rear accel pump is calibrated to cover the lean hole just like the front. If there's excess fuel, someone did a baaaad toon- downUhhh, secondary squirters DO push something. What isn't needed or used ends up in the oil, the cylinder walls, the exhaust stream, the air we breathe...
You know that they only squirt when you open the secondaries and they are never used/opened in normal driving. Never.Uhhh, secondary squirters DO push something. What isn't needed or used ends up in the oil, the cylinder walls, the exhaust stream, the air we breathe...
Mechanical or vacuum secondaries?I have a Quick Fuel Q-850 on mine, runs great.
The Q-850 series I use is more of a race carb I quess. Mechanical secondaries and no choke horn or any provisions for ever adding a choke. I like them because everything in the carb is adjustable. I have used several of them on different street cars, always with good results, both 750 and 850 versions.Mechanical or vacuum secondaries?
A Q is the performance mechanical secondary line of carbsMechanical or vacuum secondaries?
Youre builder is right. And they put 850s on stock 440s for reference, you basically have a 500.Engine builder told me he “preferred “ mechanical secondaries since vacuum cant be as “instant “ ?
And i still would like to know if i should be looking at a 750 rather than the 850?
Are you saying 750 not correct size for my 493? Remember, no racingA Q is the performance mechanical secondary line of carbs
So by your definition, is a 750 double pumper vacuum secondary appropriate?MY worthless opinion:
Throttle response will be better with a 750 than an 850
Top end power will be better with a 850 than a 750.
Mileage will be better with vacuum secondaries with either size.
For a hot rod or street strip car, a double pump 850 is called for.
If you are honest about wanting this to be a cruiser...... ? Put a cruiser carb on it.
Ahhh….ok thanksIt's either a VS, or a DP. But not both in one.
Was Johnny navigating on his little phone again???my 750 DP. Hit 129 mph in my Daytona at the Talladega Speedway
I didn’t build the motorI’m curious why you’d build a stroked big block just to cruise it.
I mean…. I cruise it too but I also peel out a lot and hammer it at WOT on occasion.
Well…. I still have a full head of hair, so no issues there. Appreciate the Summit info. Just trying to get best bang for the buck while having a great running motor. It appears from most replies, some like 750, some 850, some mechanical, some vacuum. I guess ill have to close my eyes and make a pick! LolThat is splitting hairs, man. You have it now.
Summit racing has a decent calculator to determine the CFM needs for any engine. It uses cubic inches and intended max rpms as factors to choose a CFM rating.
