I got the engine compartment pretty much buttoned up. Grille and front bumper installed. Still looking for a air cleaner base that will work with this Edelbrock carb. Time to drive it for a while.
Allagash Curieux... Good Stuff
Nicegot my engine in finally starting exhaust system tomorrow. Going to QC coatings and having that and the headers ceramicView attachment 2062804View attachment 2062805View attachment 2062806View attachment 2062807View attachment 2062808 coated black
How long did you run it at the 15v? They all run more charge after startup, but as you drive and the battery fills up it will back off the charging rate...I installed a voltmeter under the dash of my '67 R/T. I removed the ashtray and discovered that the bolt spacing that holds the receiver to the dash is the same as the meter bracket, so I mounted it there. As suspected, my battery is getting overcharged at 15 V. I would like to find an adjustable voltage regulator.
I only ran it about 15 miles on a new battery that I charged up. I'm going to run it the way it is, for now and see if it settles down. The Wal-Mart battery that was in it was starting to warn me that something was wrong. I pulled the lids off the battery, and discovered the electrolyte was down to the lead plates. I refilled the battery with distilled water, and recharged it. A couple of days later, it was struggling to start the car again. The battery was 5 years old, and I figured overcharging it pooched it.How long did you run it at the 15v? They all run more charge after startup, but as you drive and the battery fills up it will back off the charging rate...
Overcharging didn't kill it, low water did. And time. 5 years is about right for a non-daily vehicle, especially with cold seasons like you have up north.I only ran it about 15 miles on a new battery that I charged up. I'm going to run it the way it is, for now and see if it settles down. The Wal-Mart battery that was in it was starting to warn me that something was wrong. I pulled the lids off the battery, and discovered the electrolyte was down to the lead plates. I refilled the battery with distilled water, and recharged it. A couple of days later, it was struggling to start the car again. The battery was 5 years old, and I figured overcharging it pooched it.
