I bought a couple of rebuild kits and four floats with the intention of performing a thorough cleaning and basic rebuild.
Had an unusual hard time just to remove the air horn. Seemed like it was hanging on the brass air bleeds that poke through the air horn. Seems the choke shaft actually wore a significant divot in both tubes. The choke shaft is loose sloppy in the air horn. Has anyone ever experienced this. It would need to be rebushed to avoid damaging the bleed tubes. How do I fix the air bleeds?
Then there was some day 2 butchery, apparently someone took a file to the metering rods ruining them. I’ve looked at all the old strip kits and those rods are special to the hemi calibration. How can I resolve that problem?
Appreciate any suggestions
Dan
Dan
