What options have you done/seen?
67SniperHockey
10:39 PM
Minnesota
Installed a 1” carb spacer on my 1411 eddy - stock intake on my ‘68 440.
I put a 1” spacer on the throttle linkage bracket to compensate for the carb spacer - however - geometry - ha. It kicks the throttle cable way over to the passenger side and not in alignment with the throttle stud (yes I have the 1481 eddy mopar adapter plate).
What solutions are there to re-align my throttle cable on the X axis since now the height is the same with the spacer? The stock clamp has 2 sides - I already moved it over to the drivers side and it doesn’t clamp down nor is it enough movement anyways to make the cable straight.
Modify just the clamp. Add material toward the left side (a half-pipe of tubing would be ideal) to move the cable to the left.
Mike
I've bent them, welded them, fabbed completley new parts. In this case a little twist using a large adjustable wrench clamped just below the cable hold down clamp on the bracket body should get it.
Doug
I have to ask, why the spacer?
