Whats the best high temp paint for HP exhaust Manifolds?
62maxx
1:49 AM
N.W. Indiana
Good morning,
What is the best high temp spray paint and color for HP manifolds?
Thanks!
I had my hp manifolds coated by jet hot (silver) a little more expensive, but worth it.
I agree with the jet hot coating likley outlasting any paint. If you want a spray paint I like the Seymour high temp cast blast.
POR 15 Cast Grey. It cures when engine comes to operating temperature. I usually do two coats to make sure I haven't missed anything. I have a 20 plus year old restoration that looks as good as when applied and cured.
I know the manifolds aren't very well seen, but they do show.
+1 for Seymour high temp cast blast!
I used VHT's exhaust manifold paint in "cast gray" (as shown in my Bee restoration thread), baked them in the oven and then in front of my wood stove before install. 4+ years and over 3000 miles and they still look great... I'll grab a shot when I go back out to the shop to add here..
Another vote for POR15 Manifold Grey.
Prep is the key. Clean very well before application. 6 years they look exactly like the day I coated them.
Macdon221
I didn't bother spraying my exhhaust manifolds, as I had no luck with earlier attempts.
I had them coated with HPC - High Performance Coatings - basically a high temp powder coat - baked....and they look almost like they did when they were coated 20 years ago. Pro is the way to go - whatever the system.
I am sure that @CudaChick1968 could set you straight on a decent finish.....she is the Mistress of Powder ****. :thumbsup:
I have used Eastwood on three sets and no issues.
I have also had good luck with Eastwood manifold paint.
I used VHT Cast Iron header paint. Baked them on the bar-b-q for 1/2 hour at 250 degrees, and then another 1/2 hour at 400 degrees.
