The rad isn't the issue with the car. Brand new wizard rad with the larger tubes and with a shroud. 180 deg t-stat 50/50 antifreeze mix new water pump etc etc.
Car cools great on the highway -hence not a rad issue- Fan just can't move enough air and once it starts getting hot unless I can get moving at 35mph and up it gets hotter then I like. Most I've seen before I got moving was 205 which is hotter then I'd like.
Because of the large tube rad the stock fan clutch is a no go so I am stuck with the Jag based unit which is new but it never really seems to roar even when hot with the big 7 blade fan.
For those that run a 7 blade fixed fan how is it finding the correct spacers?
I know I'm late on this, but the spacers are no problem. Get the 7 blade fan that was for use without the clutch (small centering hole for water pump hub). Your local NAPA will have spacers from 1/2" to 3", depending on what you need.
