who to use for rebuilding bendix disc brake boosters?
Brakes, Steering & Suspension
  1. resq302
    resq302 Well-Known Member
    765
    196
    Jul 27, 2008
    northern nj
    Local Time:
    8:30 AM
    My chargers power disc bendix brake booster started leaking / hissing towards the end of last season occasionally when I stepped on the brakes hard. Is there anyone in particular I should stay away from? Some better than others?
    While it is out, I'm considering redoing the master cylinder also just so I don't need to worry about it leaking onto the freshly redone booster. I've heard people can have the cylinders sleeved with either brass or stainless to prevent corrosion inside the bore which would end up damaging the seals and causing a leak. Is one material better than the other with DOT 3/4 brake fluid?
  2. RT SE 440
    RT SE 440 Well-Known Member
    264
    284
    Aug 15, 2015
    australia
    Local Time:
    11:00 PM
    all my master ,wheel,slave cylinders all done in stainless steel you do it once and once only cost more but all worth it in the end .2 reasons i have all the original components re sleeved so keeps it genuine looking and 2 they will never fail again as long as you keep the oil clean they can sit there for long periods with no issues
  3. resq302
    765
    196
    Jul 27, 2008
    northern nj
    Local Time:
    8:30 AM
    how about disc brake boosters?
  4. Sixpaksteve
    Sixpaksteve FBBO Gold Member FBBO Gold Member
    343
    152
    Jan 7, 2014
    Central Maryland
    Local Time:
    8:30 AM
    Two of the more popular options for you are The Ram Man ( http://www.theramman.com ) and Booster Dewey (http://www.boosterdeweyexchange.com/)
    I've heard mostly good things about Dewey, but I used the Ram Man last year for the rebuild of my original Booster and Master Cylinder on my 1970 Cuda and I was happy.
  5. resq302
    765
    196
    Jul 27, 2008
    northern nj
    Local Time:
    8:30 AM
    I'll check into the Ramman. Dewey and I had it out the last time I called him.
  6. 440+6
    440+6 FBBO Gold Member FBBO Gold Member
    3,160
    2538
    Oct 2, 2012
    Farmington, Michigan
    Local Time:
    8:30 AM
  7. dart1962_440
    dart1962_440 Well-Known Member
    92
    9
    Jan 16, 2011
    Royal Oak
    Local Time:
    8:30 AM
    Can any of these guys convert a C-body bendix to a non-Hemi B-body one? Different brake pedal rod, not sure of any other differences.
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
