Ronald Weishaar
Need wiper motor pivots for 1965 Coronet. Mine are frozen beyond repair. Thanks Ron
Thank you for the info. I'll give it a try tomorrowSome of them can be saved if not too bad. I have drilled a 3/16" hole in the housing for a grease zerk. squirted penetrating oil in the hole and used some heat on them to loosen them up. Then install the grease zerk and give it a couple pumps. Saved some that way that I thought were frozen forever. Now, I add the zerk to all of them even if they are still operable. Might work for you since they are getting hard to find.
