WTB WTB: 1967 Charger Grill Parts
oldmangarth
10:55 AM
GA
Looking for the following:
- top driver side turn signal bracket that hold the turn signal in place and also connects to the top fender to fender plate across the radiator
- lower 2 piece grill plate that the lights and turn signals attach to
- lower driver side bracket that the lower 2 piece grill plate attaches to
- about to pull seats from car so I can rewire dash but noticed one seat was missing a post. I assume you just replace the post but don't know yet.
Here is what the lower 2 piece plate and the brackets looks like:
Need driver side bracket as I only have passenger
Need driver side bracket that braces the light and turn signal support panel as I only have passenger
Need both driver and passenger side light and turn signal support panels as mine appear to have been involved in a previous accident
I should have all that. I can get pictures tomorrow.
Awesome! Digging under the dash and replacing the wiring while I find my parts so hopefully when I put it all back together I got no excuses.
Just checking. Did you locate those parts?
To be clear I've learned how to circle the parts so here is what I'm looking for
Corner pieces and nuts for crossmember. Do you just need the 2 in the center?
Yay. So I need the entire lower crossmember and brackets that attaches it to the fenders. So you're showing the 2 pieces of the crossmember that the lights mount to that seem to overlap and connect together via a single nut. You also show the 2 brackets that mount the panels to the fender. I need all 4 of those pieces.
The center chrome piece that attaches to the crossmember would be a nice to have but might could make mine work if i do a little metal work. The other 2 pieces needed are those large brackets that connect to the top crossmember and also hold the top of the turn signal light in place.
Did that answer your question or were you talking about the 2 nuts? If the nuts I have them for the middle of the crossmember I think.
Okay. Thought you were looking for the hardware. I do have the lower crossmember and brackets. My lower chrome piece is pretty dinged up.
Do you also have those upper large brackets? And then let me know how much and how you can receive the money.
