thebankerstoy
I went and dug out a old 67 wheel I have and after looking at it, you might be able to use a 67-up wheel. It looks like they used the chrome trim around the center to size the wheel to fit the column. It's a good 1/2 wider than the base circle of the wheel. So the chrome section might just ride around the outside of the 66 column. When I ran the 66 wheel on my 67 column, there was about that much of a gap around between the chrome ring and the column.
If you want Richard, I can send you the wheel and trim ring so you can try it out on the car. If it fits, then you know you can go searching for a 3 spoker and you owe me a Coke next time I'm in Phoenix. If it doesn't work, then you know you'll have to get a 66 wheel.
And yes, not only is the trim around the base of the column different on the dash, (it's wider and made of plastic) but also the dash itself is wider to accomodate the wider collapsible column. Also, the mounting is little different underneath, 67 uses 3 mounting points, 66 uses 2.
Hi Mike,
Not only will you get a large cool drink, but a big fat steak, and all of the side fixings of your choice my friend!!! It would be GREAT to have that 67 wheel to use as a mock-up for my 66! Please e-mail me your PayPal account so that I can send you some cash to cover all of the shipping charges and for whatever you would need for the steering wheel ok? I can also give you my mailing information then. So you don't have to look for it, my e-mail is [email protected]
Man Mike, I REALLY like the look of your 3 spoke wheel in your 67 and even though it would not be techniquely correct for my 66, neither is my aftermarket tach, gauges and my console mounted aftermarket shifter that I'm going to try and hide underneath a 4 speed console top plate and shifter boot! The 67-69 wheel will still look a LOT more factory than any aftermarket wheel also, so thanks my friend, if that 67-69 wheel will work, that's what I'm going with, IF I can find one WITH a horn ring in excellent condition! ;)
Thanks againg to ALL of you folks who have taken your time to help me out on this subject. I can't wait to get your ideas on hiding aftermarket shifters in factory consoles!!! ;) Man, I really LOVE this web site!!!
Richard
