Pictures of My Cars #'s
The Rebel
1:38 PM
SW CT
Now that my car is back from the shop I've had some time to get pic's. Just need everyones help on a few items. Based on what I've found looks to me a #'s car correct? Do I need any other #'s to verify I this is truly a #'s matching car?
Head- 2843906-6
Engine- 246813-7 LL Date code on block 5-17-67 I'm assuming the 2468137 is the part #What does the "LL" Stand for? Also assuming the N & D are to designate the Night & day shift correct?
Transmission- PK2892031K 23647333. Need help breaking down these #'s.
Pad says D383 1 23 2 - D = D series, 383 = Engine 1 23 - Jan 23. Does the last 2 Stand for 2 BBL?
For the rear it has the 489 case. What does the Triangle mean as well as the 4 above it.
Rear has the 3.23 tag on it as well.
I thought this has been previously covered?
You were told that the block, rad support, and vin matched....in relation to the build sheet.
The other vin numbers are on the driver side trunk lip....
Your trans has NO stamping in relation to vin.....
489 cases was 69-74......
So based on your paperwork and stampings the block mates with the body and build sheet(assuming the trunk lip matches).....the other parts just complete the puzzle of driving it....
Back then I did not have clear pic's of the block/tran but now I do. I also discovered on the pad a #2 after the 1-23. So not sure what that meant.
So the 489 case was not offered in 68, meaning it was swapped out at some point. What does the Triangle mean as well as the 4 above it.
Also want to understand the #'s on the engine. Engine- 246813-7 LL Date code on block 5-17-67 I'm assuming the 2468137 is the part #What does the "LL" Stand for? Also assuming the N & D are to designate the Night & day shift correct?
Based on all of the #'s it appears the car is #'s matching for the block & tran, but NOT the rear.
Where's the vin stamp on your trans? The pk numbers are trans related numbers and not vin numbers....
The 5/17/67 is the block casting date....when the block was formed...the other number is the casting number relating to a 68 383 block....the ID pad date is the build date of the motor in relation to the build date of your car roughly...
The triangle is a manufacturer mark...means nothing other than on a 489 case will have that. Find a 742 case and your rear will be complete....
On paper and stampings your block, rad support and build sheet match, that's it..
People will say 68 was a weird year due to the way they started things....but I have not seen a block stamped and the trans not or vice versa....All 68 I have had, had both stamped.....
People will argue that some received no stamps early on or at other plants.....
An elderly friend of mine retired from Chrysler years ago. While talking about his days there he told me, sometimes they didn't change date codes for weeks !
Change? Lol....
tell us how they changed the dates?
Roger
Contact... 69coronetRT
Give him all the pertinent information...because others posting with stories etc and misinformation are not going to give you concise information.
iMHO he is the most knowledgeable when it comes to anything numbers/production related....he knows the plants variances an compiles research to this day....
Changed the date stamps. My point being, the date on any part may not be accurate.
OE correct builds are my arena in this hobby....for over 20 plus years....
Part dates are waaaaay different than engine assembly dates....
It is a know fact in relation to parts a 3 month prior to actual build date window is acceptable....
I'm sure youre correct. I wasn't contradicting. Simply offering related info, if, that is ok with you.
No worries Aaron...I was simply clarifing the actual, that all...don't take it the wrong way...
I didn't intend to. I believe i am a bit jaded. I've only been on here a short time. But from reading various threads here, i get the feeling more of a court room & less of guys chatting about & enjoying their Mopars. IMO. No offense intended.
You haven't been here long enough....this forum is the best on the web and a great group of guys in the Mopar world...
We have very well versed and experienced guys here that are passionate about mopars and the true history....we will not beat around the bush and will be direct...that's it...straight up honest answer....
Most take it the wrong way and me and others that are blunt in reality would be your next best friend....
You are at the right place in time you will see....
2468130-7 = 2468130 casting# for 59-71 383B, 7th "mold" (#core plugs replaced in casting)
LL = someone please tell!
D = day shift, cast during 2nd hour of shift
5-17-67 = casting date
D383 = 1968
1 23 = assembled Jan 23, 1968
2 = 2nd shift
VIN Block/Trans: I agree if the block has the VIN, so should the trans as stamped at same time.
PK2892031K 23647333
PK = Kokomo IN
2892031 = A727 1968 for 383-4
2364 = Wednesday, January 17, 1968
7333 = 7,333rd transmission built that day
Thanks for the breakdown!
D383 = 1968
2 = 2nd shift
PK2892031K 23647333
PK = Kokomo IN
Roger
Thank you for the kind words. There are others on here that know far more than I do about 68 Chargers.
A couple of thoughts...
This shows why the SPD is NOT the build date but only a SCHEDULED date. The engine was assembled a day after the SPD. Figure it took a week to get the engine to the plant. It's likely the car was assembled around January 30th.
VIN stamping on engines and transmission housings is an interesting topic and this is a good example. Research continues.
The 237 axle assembly code on the Broadcast sheet tells us the rear came with a 1 3/8 pinion so it was a 741 case.
While more common to '69 and later, the 489 case was released late in the '68 model year. Check the casting date on the housing.
Why would that be an issue, someone counterfeiting VIN's?
"Safety precaution"
Do not ever post a complete vechile vin.
Thanks! I tried sending you a pm but your inbox is full.
