Mike67
He is correct, that in order to get the designed efficiency for exchange rates, the system relies on time/volume and temp calculation.I totally disagree with your premise...velocity of the cooling medium, either on the air side or fluid side is critical to heat exchange pt
The flow can be too fast, but that is also what the tstat helps to do by restricting the flow.
