photo or diagram how to reroute the right front brake line
CRAIGXLH1
1:20 AM
CHICOPEE MA
Hi do anybody have have photos or diagrams how to reroute the right front brake line on the firewall. On a b-body so I can go to the drags race. I have a 69 GTX last time at races a few years ago they told me that had to reroute my right front brakes line. thank you
Back in the day we had to run the right side line in front of the engine. Not on the firewall but that was 100 yrs ago talk to dvw,malex Mike Gaines and nss these guys have the rules down and could give you insight. Racers hangout good luck
I saw this on a Sox&Martin car.They ran the brake line from the master to the front,around the bottom of the rad support and over to the right side .
I did it that way and ran rear out side frame rail. Used insulated clips to hold them. Wait for the race guys though.
i meant the stock location of right front brake away from the firewall away from the rear of engine
i meant the right front brake line away from the firewall stock location and away from the rear of engine sorry for the mix up thank you
You run the brake line forward along right frame rail then down under the radiator. Run along left frame rail to junction block. I did mine with no radiator in the car, didn't want run it on bottom of radiator support . Used insulated clips to hold it in place.
It was to move brake lines away from possible clutch/flywheel explosions cutting brake lines.
Don't know what classes it applied to.
2018 NHRA general rules on brakes -
"General
Regulations
Section 21, page 17
General Regulations
Brake lines must be steel,steel braided, or DOT-approved flexible and routed outside the
framerail, or enclosed in a 16-inch length of 1/8-inch minimumwall thickness steel tubing securely mounted where line(s) pass the flywheel bellhousing area and not routed in the driveline tunnel."
Since you have to redo the line on the firewall just to enclose it in the tubing, you might as well reroute it.
Barb Cooke's 69 RR race car -
"General
Regulations
Section 21, page 17
General Regulations
Not to get off topic but what purpose /benefit is it to have a manual prop valve feeding into a distribution block (auto prop)????
Good question Mike. I'm really not sure why. It's just a distribution block so I'm guessing it made the routing to the rear easier or cleaner.
The only reason I can think of not to do it that way is if you have a brake warning light hooked up. The distribution block has a pressure differential switch that would light up, meaning there is a brake problem. Think this is the reason?
She's not utilizing a warning light so I just don't know for sure. I'm going to ask because now I'm curious.
I'm no brake wizard and am still learning my way around the black magic that makes systems work.
Its hard to see the block in the pic but it sure looks like a factory type prop valve...are you sure it's just a distribution block???? Or am I misunderstanding when you say distribution block???
Thanks Shorthorse/Fran!
Looks like Shorthorse used d block for front brakes only.
can someone tell me what gearbox that is. don't want to steal or invade on the brake stuff just need to know. thank you for the help
