Factory 4 piston bendix calipers
Gary Milton
3:13 PM
FL
Does anyone know where I could find a rebuild kit for these calipers also, in need of one hub. I got all this stuff from a package deal and I'd like to put them on my roadrunner. Thanks guys!
Do yourself a personal favor and locate a caliper rebuilder near you. They will dismantle, clean and inspect the unit and if still useable, hone, polish and rebuild them with the right seals. If the bores are good but the pistons crap, they can replace them. Cost is usually very low and you can be sure of their performance. Finding new seals requires skill as their sized by the thousands and the gap between the piston and the bore is critical.
I got a kit from Harmonclassic brakes.com for mine.
Need to send them out to be sleeved.
Joey D
It is common to sleeve calipers in the GM world. Find a Corvette caliper rebuilder.
If you need, as you are putting your car together ---- I have -- BRAND NEW ---- Master Cylinder, Front Brake Hoses, Front ++ N.O.S. ++ Asbestos Brake Pads,
Front U.S.A. made Inner & Outer Bearings & Seals, and N.O.S. ++ Asbestos ++ Rear Brake Shoes for both 10" & 11".................. to treat your car right!!!!!!!!!
And ----- N.O.S. Front ROTORS and Rear Brake Drums...........
