superbeerick
Does anyone know the correct ignition timing for an A12?
"Officially" (factory specs) it's initial of 5BTDC, vacuum advance disconnected and plugged of course.Does anyone know the correct ignition timing for an A12?
12-14 initial & 36 total while im no expert its a good place to start.
Gentlemen,factory Prestolite distributor initial timing would be TDC for manual trans, 5 BTDC for automatic. if your using stock/original parts by no means do anything even close to 16 BTDC; 10 BTDC is too much. the factory distributors had a lot of degrees in them.
