4mulas
- 5:59 PM
- Mar 16, 2017
- Just North of Montana
Planning a sniper install on a 69 Road Runner and have read (I think) every post and thread about EFI installs that I could find, good tips here and there and recommends on much of it, but what I’m really looking for is opinions from real world users about what they did for fuel delivery and what they have learned or may change for future installs.
I’m going to use the EFI tank with in-tank pump utilizing a feed and a return - both 3/8”
Was thinking about running 3/8 hard line for the majority of the car using steel braided AN hose (6AN) for the connections at each end (the last 18-24” or so). With a 10 micron billet filter on the supply line.
I’m wondering if it’s overkill or if I should just run braided the whole way or just plain earls rubber line etc…. IE: should I make it as easy as possible? What about push lock or twist-loc fittings too? Are they reliable and safe?
Did everyone put a 1/8npt fuel take off fitting for a pressure guage as sniper instruction recommend you do? Is it really necessary? Should I do it right off the throttle body? Do folks use straight hose ends or maybe 45’s coming off the throttle body?
Is there differences in qualities of braided line or are they about all the same? Same question about the plain stuff like earls or Russel etc..?
Also, maybe @andyf can answer this, can you buy AR engineering stuff direct from Andy or do you have to order through his list of dealers? I’m very interested in the throttle cable bracket and thermostat housing with temp sender port…
I’m capable and very particular about clean and proper, so with an eye to that any help is appreciated…
Any help before ordering a whole bunch of wrong stuff (lol) is really appreciated! Any pictures or recommends also very welcome. Thanks!
