Car #4
After removing and replacing the instrument cluster the right turn signal doesn’t flash. So I pulled the light out and made a ground with my test light probe on the metal tabs of the socket and it works. So definitely a grounding issue. Took a little sand paper and cleaned the tabs and cleaned the edges of the hole that the socket goes in as best I could. Light doesn’t work except if I pull the socket out and hold it in the hole at a cock-eyed angle it will work. How do I get it to ground when the socket is installed properly? What’s frustrating is that it worked before I removed the cluster.
