CoronetDarter
In California its always trans swap time!Greg, have you finished the Borgeson swap?? Sounds like it's trans swap time....
I started swapping the pedals on Saturday. I'm going to post about it tonight.When does the install begin?
SST is very adamant about checking and correcting the TIR. Their warranty is only good if you send proof of verification and alignment. To that end, I ordered two sets of offset dowels from Robb Mc; they'll accept returns on the unused pair. The Robb dowels are .496" diameter; most parts houses like Summit sell the Mopar/Ford dowel which is .500". Works for Fords but I've heard the horror stories trying to pound them into a Mopar block.I have the SST TKX in the ‘68 Coronet and would do it again in a heartbeat. Few things, indexing the bell housing is critical and will most likely require offset dowels. You will need to do a mock up first and measure before you know what you need so add a week for the mailman to your schedule, lift time.
Yes, the kit came with the OBP master cylinder. Disappointing since the TKO's came with Wilwood. Haven't decided what to do yet. There's no mention in the paperwork about the slave throw. I'm going to call SST and ask about it.The Wylwood slave cylinder is far superior to the OPB chinesium crap. I do not know why SST would include that junk in such an expensive package. If they sent that one, change it to or you will be back underneath when it fails internally. There are actually 2 choices on the slave throw. .75” and .625”. They do not give you a choice but they should. The .625” gives a much shorter throw but delivers a heavy pedal. I have run both and kept the .625” in place. It depends on your driving style but for slamming gears I want it short and to feel the pedal. You will need to make a pedal stop that is not included in the kit. You can blow out the slave cylinder if you do not do this. It also lets you customize your engagement/release point to your liking.
I didn't special order a QT bell and there's no mention on the order or markings on the bell so it must be the standard.Did you get the standard bell housing? Or the Quick Time bell?
Local guy bought the Q/T bell & it wound up being over .060 out of alignment... I machined custom offset dowels to get if in the ballpark... Then the bolt holes needed to be opened up... He scrapped the Q/T & bought a regular bell, it was within .006 out of the box..
This one?I have the SST TKX in the ‘68 Coronet and would do it again in a heartbeat. Few things, indexing the bell housing is critical and will most likely require offset dowels. You will need to do a mock up first and measure before you know what you need so add a week for the mailman to your schedule, lift time.
The Wylwood slave cylinder is far superior to the OCB(sp?) chinesium crap. I do not know why SST would include that junk in such an expensive package. If they sent that one, change it to or you will be back underneath when it fails internally. There are actually 2 choices on the slave throw. .75” and .625”. They do not give you a choice but they should. The .625” gives a much shorter throw but delivers a heavy pedal. I have run both and kept the .625” in place. It depends on your driving style but for slamming gears I want it short and to feel the pedal. You will need to make a pedal stop that is not included in the kit. You can blow out the slave cylinder if you do not do this. It also lets you customize your engagement/release point to your liking.
If on install,it will not close on that last 1/2”, do not force it. The splines are not lined up. I think the original alignment tool that they were sending out was just a hair small(now corrected). I had to get the clutch engaged to get it installed. Much easier said than done on your back with an uninstalled transmission hanging in the air.
I am sure that Kerndog can add a few inputs to keep you from making some of the stupid mistakes that we fought thru.
Yep, that's it.
I hope it works out for you, my friend had to send his back.Yep, that's it.
I had to learn as I went. I saw that the cowl vent had to come out to get the long pin out that both the clutch and brake pedals hinge from.Looking at the instructions, swapping the pedals should be a straightforward operation. But first, lets talk about the instructions. On the whole, SST's instructions are pretty good. They're very detailed on the assembly, very vague on the disassembly. I get it, the disassembly is a one-size fits all guideline, while the assembly is Tremec specific. For the pedals, there's only 4 steps to disassembly, and 20 for reassembly.
I don't. I've taken it down Sac raceway a few times during Mopars at the Strip, but I didn't get any good runs in.One advantage of the TKX is supposed to be the ability to shift better at RPMs over 6000.
My TKO is a bit stiff when trying to power shift at 6000 or thereabouts. It probably isn't important though if the engine HP peaks below that. I just get so excited when driving fast and hard, I am caught up in the moment and the engine speed gets away from me.
Any idea of where your 440 tops out?
Its a stock analog speedo, so the cable is OEM on the one end and Tremec specific on the other.I had to learn as I went. I saw that the cowl vent had to come out to get the long pin out that both the clutch and brake pedals hinge from.
Regarding the speedometer. I'm guessing they included an electronic speed sensor/Pulse Generator that allows you to attach a stock speedometer cable?
Here are a few pictures I found online.Looking at the instructions, swapping the pedals should be a straightforward operation. But first, lets talk about the instructions. On the whole, SST's instructions are pretty good. They're very detailed on the assembly, very vague on the disassembly. I get it, the disassembly is a one-size fits all guideline, while the assembly is Tremec specific. For the pedals, there's only 5 steps to disassembly, and 20 for reassembly.
Step #3: remove pivot pin nut from RH side of housing. Two minute job. But the Coronet has another bracket attached to the brake cage that shrouds the nut. I spent waaay too much time trying to reach the nut with the bracket in place. Can't be done - have to remove the bracket. The bracket is attached to the cage with three bolts and a nut. I removed two bolts and nut and the bracket wouldn't move. WTF?? I finally realized that one of the bolts also holds a U-shaped bracket that supports the main wiring harness. The harness was obscuring the bolt head. Pop off the harness, bend down the bracket a little to expose the bolt head, and off it came. Now the pin nut is exposed. I spent over an hour on this part alone; knowing what I know now it can removed in minutes.
The hidden nut:
I needed the .007" offset and used the same ones you have. The hardest part is understanding which way to move them. If you draw it on paper it makes sense.SST is very adamant about checking and correcting the TIR. Their warranty is only good if you send proof of verification and alignment. To that end, I ordered two sets of offset dowels from Robb Mc; they'll accept returns on the unused pair. The Robb dowels are .496" diameter; most parts houses like Summit sell the Mopar/Ford dowel which is .500". Works for Fords but I've heard the horror stories trying to pound them into a Mopar block.
I didn't have a dial indicator to measure the runout. This is one of those instances where I need a tool I may never use again. I wasn't going to spend hundreds of dollars on a Starrett indicator and Noga base, but not HF either. I settled on a Wen dial indicator and Clockwise base. Machinists may roll their eyes on the Wen, but it got 785 reviews on Amazon with a 4.5 star average. The base seems to hold:
View attachment 1531884 View attachment 1531885
