Eric F
- 11:03 PM
- Jan 22, 2023
- Atascadero California
1970 Road Runner. The vehicle has what feels like a driveline type vibration that comes in about 65-66 mph. It turns into an oscillating type vibration around 68mph to about 72 then the oscillation tapers out. About 2800 -3200 engine rpm. I bought the car in 2019 and was a rolling body. It came with the original engine rebuilt. A rebuilt 727. When I installed the engine and transmission I installed a Hughes unbalanced converter as the 383 is internally balanced. I used all new engine and transmission mounts. When I went to install the original driveshaft I noticed there were hose clamps on the shaft near the front joint . That tells me that someone was chasing a vibration before the car was taken apart.(car sat apart for 26 years) I took the driveshaft to a local guy who installed new joints and balanced the original shaft. He stated it was really close. I got the car running and experienced the vibration. I checked my driveline angles and found my drive shaft is at 1.8 degrees. Well within the .5 to 3.0 all internet car builders and guys who do custom engine swaps set there’s at. I had my local guy build me a driveshaft actually measuring from the transmission to differential. Guess what length as stock. I changed the complete center diff assembly from 3.55 to 3.23 all that did was change the speed the vibration is at. Still,same rpm. I changed the axle bearings to Green bearing from mopar. NO change. I swapped the axle from another set I had and on these I used DR diff’s bearing(updated green bearings with snap rings) no change. Again checked the driveline angle and came up 1.8 well within tolerance. I’ve tried different rims and tires from another car just to rule out my rims and tires no change. I had an oil leak from the front crank seal so at the time I installed a fluid damper of course NO change. I did replace the transmission tail housing with another one. I made sure I replaced the seal and bushing. The bushings was worn. The output bearing is ok. I recently replaced the rear leave springs bushing as the car had urethane bushing no change for the vibration . Just a little softer ride.
Driving the car this weekend I did notice that as the ride height changes due to road conditions. I.e suspension loads it’s seems to get more pronounced.
The suspension unloads it diminishes.
I did some research and found out the transmission that was in the car when it taken apart years ago had a cracked case. The shop that did the transmission swapped the parts from that transmission to a different case.
Please make to read the complete story before answering it’s this or that when this or that have already been replaced with NO Change.
